Enable VLACP Globally
Enable VLACP globally to detect for end-to-end failure. VLACP uses the Hello mechanism of LACP to periodically send Hello packets to ensure there is an end-to-end approach. After Hello packets are not received, the VLACP transitions to a failure state and the port is disabled.
- Select MLT/LACP.
- Select the VLACP Global tab.
- Select VlacpEnable.
- Select Apply.
VLACP Global Field Descriptions
Use the data in the following table to use the VLACP Global tab.
Name |
Description |
VlacpEnable |
Enables VLACP globally. The default is disabled. |
